Mercruiser Tach stuck at 2000 rpm's
Johnny Be Cool
1990 350 Thunderbolt Ignition Alpha 1-
Would like to know if my tach is bad or if there is a wire problem.
I've read this on this site:
For the tach to work: You need black (ground), purple (key on power) and gray for the signal. With engine running, test the connections with electrical tester. When revved up, the gray signal wire should read a few volts. Barely any at idle. For tach lighting, you also need the blue wire.
Does that apply to my application. I know on cars the tach reading is from the coil, not sure on my ignition where to start looking.
Can someone tell me where the signal starts, what color wire, etc....
Thank you in advance.
John
cr2k
Re: Mercruiser Tach stuck at 2000 rpm's
That is correct wiring. Your tach may be bad.
One solution is to only go at 2000 RPMs then your tach will always be right.
Johnny Be Cool
Can someone tell me where the signal is coming from regarding my application.
Does anyone have a wire diagram?
dubs283
gray wire is the signal wire for the tach
it is attached to the (-) side of the coil
wiring diagrams are located in the proper manual pertaining to your engine
i agree with cr, your tachometer is most likely the culprit
