Mercruiser Tilt/Trim Dual Solenoid Hook Up (W/Pics)
LX Kid
Ensign
I had to replace everthing on my dual solenoid tilt/trim assembly. I bought new motor, 3-wire, and I used Autolite autmotive solenoids, which have an "S" and "I" terminals. My question is are grounds connected to the "I" terminals includeing the support frame for the solenoinds? I hookded the connector plug wires to the "S" terminals. In a automobile configuaration the "I" terminal usually goes to the ignition coil. Thanks, Ron
THIS IS THE TILT/TRIM THAT THE SELLER HAS JUST USED LAST WEEK!!!!
THIS IS THE WAY I HOOKED UP THE SOLENOIDS. (HOPE EVERYONE CAN TELL FROM THE PICTURES) The lower solenoid connection "I" terminal is actually a ground wire going to chasis ground. (Looks like a red wire but is really a black ground wire.)
Don S
Re: Mercruiser Tilt/Trim Dual Solenoid Hook Up (W/Pics)
You have the wrong solenoids, those are start solenoids, if you hook the grounds to the "I" (Ignition) terminal when you engage the solenoid it will create a dead short to ground. The ones you have MIGHT work, if the base of the solenoid is hooked to ground, and the wires removed from the "I" terminals
LX Kid
Ensign
Thanks Don. That is what I was also thinking becaue the "I" terminal on these solenoids puts a positive to the coil in an automobile configuaration. I'll disconnect the grounds on the "I" termionals and give it a a try. Ron
LX Kid
Ensign
Problem resolved! Thanks Don. Auto solenoids get their grounds from their mounts and the "I" terminal is not used. Ron
