mercruiser timing
brodie123
Hi All;
i just rebuilt a 165hp Mercruiser I/O - new crank/cam/pistons etc - done by a pro shop
I think the carb needs a rebuild - lacking HP on top end and bogs under fast throttle up
the issue is timing - I bought an adjustable timing light from princess auto - set to 6 degrees and she starts well but lacks HP - problem is corrected by going up on the timing
question: what is a safe higher timing or is 6 degrees a must?
why would the higher advance give more hp?
fyi: electronic ignition
any adivce?
Scaaty
Re: mercruiser timing
You posted in the Outboard Forum...I'll contact a Mod, and move it to the I/O Forum
Don S
Is this a 6 cylinder or 4 cylinder engine?
brodie123
thanks for moving the post - brand new to the site
It's an inline 6
Fishermark
Check the advance weights under the plate in your distributor and see if they are binding.
Ayuh,.....
While you Can advance the timing above the 6?,......
If you Do,.....
You risk Smoking your Brand New Motor......
Fix the Carb.....
brodie123
Thanks. I had the carb rebuilt - still lacks top end. Had the intake manifold press tested and found a crack. :-( Can't find a replacement :-((
A good welding company said they should be able to fix it - is this a good idea?
Any suggestions on where to buy?
Would a small leak from water to exhaust cause a top end power problem like I am having?
thanks!!!!
brodie123
I found a manifold - but it's a 2 barrel not a 4. I have a 2 barrel rochester on the boat now - it uses a plate as an adapter.
Am I safe to go with this other manifold?
JCF350
As long as the carb is marine your safe.:)
