Re: Mercruiser Timing
I have set mine at 6-7 degrees BTDC AT IDLE . I have a 5.7L mercruiser with Edelbrock 600 cfm 4bbl double pumper. I have a heavy boat @4500lbs. Put your drive all of the way down when you set the timing. bring a friend who can safely steer the vessel, and a timing light, and play with it until you feel like it is operating to the fullest capacity. DO NOT GO MORE THAN 12 DEGREES BTDC!!!!! Also keep in mind that you want to tune the motor to stay in the torque band 3200-3850 RPM. I recommend running 93 octane because it stops predetonation, and burns more efficiently. SPEND THE EXTRA FEW DOLLARS AT THE PUMP, AND YOU'LL NOTICE THE DIFFERENCE. You might need to upgrade your ignition. Check the coil as well. I wouldn't worry too much about 100 octane unless your compression is over 11:1. Make sure your cylinders cancel when you drop them 1 by 1. check your wires, cap, rotor. you may need hotter or colder spark plugs according to engine operating temp.
