Mercruiser trim goes up but not down
bad67nova
I have a 70 imp boat with a mercruiser I/O tue trim goer all the way up but it wont go down .how do i bleed it or what is the problem?
Re: Mercruiser trim goes up but not down
Ayuh,......
No Bleeding necessary,......
You might try Greasing the pivot pins
Btw,......
Can you find a Bigger Chart Don,..?? :D
Don S
Ayuh,......
Btw,......
Sorry bout that. I knew it was big and was planning on just putting a link to it. :redface:
I will edit it and make it a link, not the picture
Haut Medoc
Welcome to iboats......:)
Does the trim motor make noise when you push the down button?.....
If it does try having a helper push the down button while you stand or apply downward pressure.....
There is alot more psi going up than down in the pump, & sometimes a bit of corrosion can make it tight...
Greasing the hinge pins & anchors pins would not hurt....
How freely does it move up & down with the trim rams disconnected at the aft end?.....
If that doesn't work, you may have pump problems....
You need Merc. Manual #1, I think I have a free link, but it is a big download, let me see if I can find it.....:)
