Mercruiser trim pump issue
Jakem
Good day. I have installed a used trim pump in my 1975 campion boat. It works good aside from these 2 issues. First being when I put it all the way down it comes back up a bit on its own. Second when I'm trimking up or down while under way the alt meter on dash jumps up. Any ideas
1960 Starflite
If the engine is running while operating the trim, the alternator senses a demand and applies more amperage.
If engine isn't running, something is weird :(
Jakem
Gotcha. Yes that's what it's doing so all good. Thanks
04fxdwgi25
The creaping back up may be air in the system.
The dash meter jumping thing is normal when engine is running and there is a drain on battery from high electrical load being used.
Jakem
Right o...I'll bleed air out I appreciate the help
