jakwi
- Joined
- Jan 7, 2019
- 184
Thanks again for the help guys, Just having someone to bounce ideas off is tremendously helpful. Yesterday I pulled the shift interrupt switch again. It is a sealed plunger type switch, but I sprayed some contact cleaner into the gap around the plunger and worked it for a while. I was able to get the closed resistance to .3 or .4 ohms and the open resistance is still OL. So as far as I can tell there is nothing wrong with the switch. I also inspected the harness as well as I could and rewrapped it in spots that I felt were at risk for rubbing through vibration. One spot in particular was back by the coil on the oil pressure sensor. I didn't see any exposed wire, but I wrapped the harness in that area with rubber tape, and ziptied it in a way to keep it from rubbing. I also double checked the grounds, and rearranged the wiring to the coil so that there was no risk of rubbing through the insulation.
As far as the knock sensor. That never occured to me. I'm pretty sure I can eliminate that on my next test run by jumping the purple/wht wire to ground, but I supposed I could always just unplug the sensor. I did try that back when I was having issues with the coil arcing, but I think that was a different issue. Luckily that sensor is fairly affordable. $30ish if I go with the one from Autozone, or $55 I think for the mercruiser part. ... any reason I can't use an automotive one? They look identical.
So for my to do list. On my next run, I'll disconnect the shift interrupt switch, Knock sensor, and Tach. The weather isn't looking great, so it might be a couple of weeks, until I get the next chance.
