turborich
Thread starter- Joined
- Aug 29, 2008
- 132
Ok guys, The mercruiser drive is junk & I have a replacement that I will be putting on soon. The last guy who owned the boat really screwed the outdrive up when he tried to fix it himself, anyways.
the gear lube has leaked out of the small hole near the bottom, I hooked up the clam shell & garden hose up yesterday so that I could start up the engine. (I am not concerned with the drive getting messed up because like I said I have another one that is good) I turn the hose on & start the engine. Water was leaking inside the boat through the gimbal bearing/drive shaft. How could water be getting through there? It's not in the water, only hooked up to a hose. Is it possible the water is being forced up into the top of the drive & out where the drive shaft is due to bad seals?
This is the only possible thing that I can think of. I will be pulling the drive off in a couple of days & I'm sure I'll figure it out then, but for now I was just very currious as to if this was possible?
Thanks, Rich
Thanks, Rich
