peanutbay1
- Joined
- Jun 4, 2009
- 91
Ok here is the information;
90 mercruiser 5.7 with alpha one outdrive. 1990 bayliner 2755 sunbridge. This boat was in storage for 3 years. It was stored correctly and everything has come back on line flawlessy. What we discovered was the circulating water pump was shot.So we decided to change both the circulating pump and the lower unit water pump. What occured after the repairs was shifting was not interupted correctly by the interupt switch.
Ok her is the problem:
I replaced the water pump in the lower unit. I removed and reinstalled as per the manuals instructions. We acutually did the procedure 3 times to verify it was done correctly. Prior to this repairs the shift interuption worked corrrectly and since this repair it is not being mechanicaly activated. The switch does work and it is centered in the cam as it should be. My question is:
By doing this repair is it possible that I will have to readjust the shift and remote cables????
