mercruser lower leg shift problem
stujoe
hay does any one know if there is any more adjustments on the shifter from the end of the cable to the lower gear case, the end play on the prop shaft was 5/8 of an inch wich seemed to much so being a mechanic my self i took out some end play wich is now 1/8 but lost reverse tryed to pull of the leg again!!! ( the boat was on the bottom of the lake before i got it long story) and turn the splined shaft one notch which didnt help..???? sj 8)
Don S
Re: mercruser lower leg shift problem
Mercruiser has made many different types of drives since the mid 60's. Suppose you might find your way to give us a hint as to the year and model of the drive you are talking about.
By any chance were you using a manual or was this just a "seat of the pants" type fix you did because you are a mechanic?
freddyray21
Don I answered him in the other post he has going on the same subject. He adjusted it so much he doesn't have reverse now?
