i have a 89 4.3 with a mercruser outdrive just got the boat and the propshaft seal was out of it got the pro off everthing down to the bearing housing.. was woundering if i should take the porpshaft all the way out and any tricks i need to know when putting it back together i am not very experinced with boats but mechanicly inclined. also the end of the shaft will move around left and right about 2-3 inches not up and down ON THE PROP END but not near the foward and reverse gears is this normal ok? here are some pics everthing lookd great..
http://pictures.sprintpcs.com/share...vYJzakMx&shareName=MMS&messageState=RETRIEVED
