Re: Mercrusier 228 Overheating
I replace the base of the outdrive pump as well.<br />Forgot to mention that the guys who winterized my boat fryed the pump & housing. I also found the T-stat hose & riser hose was crossed on one bank. Today I checked the outdrive pump with muffs & pressurized it. Saw some water coming from the base near the inlet grates. Tightened it up & it went away. <br /><br />My boat is 20 years old & only used in freashwater. Today I cleaned out the manifold riser & probed them with a rod. Also flushed the elbows with acid. They were not that bad, some rust.<br /><br />No time to finsh, got dark. I will let you know what I find out or if you have any other things for me to try. Please let me know. Thanks for the help!
