Mercrusier 3.0 and 4.3 compatiblity
Tommy2082
Hi i have an 87 sea ray seville with a 3.0 mercrusier with a bad outdrive. I have a good outdrive from a 4.3 mercruiser. Mu question is will it work with the 3.0 motor or do i need to find one from a 3.0 thanks in advance.
alldodge
Yes, so long they are the same type Alpha and MC1
Alpha Gen 2 will not
you can get props low enough if the drive is a 1.81:1. however if its a 1.62:1, no
also, the inline motor has a different input shaft than the V-motors. you will need to swap input shaft
Tommy2082
I do have another question. I know quite a bit about outboards but this is one of my first i\o boats. I can not get the outdrive to go into forward gear. It will only want to go into reverse. When i pulled the outdrive it worked fine. I know you are supposed to install them in forward gear. Is there something that i am doing wrong?
alldodge
Alpha 1 was from 83 to 90, only the earlier drives have different input shafts
alldodge
Need to turn the shift foot to face straight forward on the drive to align with the other half on the bell housing
Tommy2082
I have it turned straight but it keeps wanting to go into reverse when i spin the prop.
alldodge
Rotate prop counter clockwise (reverse) until prop locks. Put bungie on prop to keep it that way, then install
QBhoy
Engine mounts pattern are different, exhaust cow horns too. Big one is all dependent on gear ratio. Someone will tell you more than I...but I know that most 3.0 will be a 2-1 or 1.8-1. 4.3 will usually be a 1.6-1 or 1.8-1. Then the wild card is high altitude.
