mercrusier 3.0 water in oil.
Loosingbattle
I have a 1990 bayliner with a mercrusier 3.0 inboard,like always I was checking things getting it ready for the 4th of july weekend, I hooked up the garden hose to the lower unit, and started it up, started right up, like always, went in the house to get something to drink, while it warmed up, came ,back and removed the engine cover , and thats when I noticed water leaking from both sides of the manifold on the second bolt from the front of the engine, engine still running great, no misses or skips, 165 normal temp, so I shut it down and pulled out the dipstick to check the oil, and thats when I really went crazy, the oil looked like coffee, with a lot of creamer in it, PLEASE HELP, THANKS.:(:(:(
dubs283
Re: mercrusier 3.0 water in oil.
any sever overheats as of late? engine winterized properly? could be one of a number of problems causing this
P 0 P E Y E
I would suggest you remove and inspect your spark plugs for signs of water.
When an exhaust manifold lets go, or fails it will allow water to enter into the combustion chambers of one or more cylinders.
The exhaust manifold and mixing elbow are cast iron and fail at about 10 years of service.
Check for water and let us know.
Good luck
hammerfist
i have an 87 capri 2.3 ford omc, i prepped my boat as you did for the 4th weekend, no probs., got to the lake, run for about 20 minutes, daughter says dad your engine is smoking! i shut her down and inspected, water was gushing out of my manifold riser, checked oil, no water in oil, that was a good sign!!!! thinking the gasket blew out, i limped her back to shore, on further investigation i noticed two bolt had snapped on the riser! (the riser bolts to the top of the back of the manifold and connect to a rubber boot for exhaust) oh by the way, im also a newbie at boating, this my first boat. anyways, looked like an easy fix though my weekend was ruined, i trailerd boat 200 miles to enjoy the weekend. got home, started taking apart and snapped another bolt! got it all apart, soaked in muratic acid to clean tapped new holes started scraping old gasket off and noticed the exhaust ports were starting to corrode in the middle of the manifold and the riser, im wondering if yours had corrodid to the point that its letting water inthrough you ports?? i may be out of a manifold and riser myself, very expensive for a FORD omc! and rare. please post on how it turns out!
danond
Hammerfist - your manifold is shot if it's rusted through. They're not repairable at that point.
buddybarnhill
ohhhh man i feel sorry for you like the last guy said manifold is rusted or yoiu have a crack head both non fixable shall i say new engine for you mister
wanna-be
remove the spark plugs and crank engine. does water spray out? yes...crack block, cracked heads, rusted manifold...not good
buddybarnhill
wanna be the motor will not crank with spark plugs out it will turn over but not crank no spark to ignite gas no crankie
wanna-be
for buddy's sake..."spin the engine"
Ayuh,.... Around Here,....
If the motor is Cranking,... It's being turned over by the Starter....
If it's burning fuel,+ making noises,... It Running...
Loosingbattle
the engine runs great, I can see the crack underneath the carb, water is in the oil,everyone is telling me cracked block, because if the water was getting on top of the piston , it should be skipping , right!, alot of searching the internet people are saying its the manifold / riser rusted out, and or cracked, how is water getting in the oil, without the block being cracked, I do not understand, PLEASE HELP, i just had all the upholstery done $1300.00, and now this , can someone give me a positive direction, please! thank all of you for your replies.
marlboro180
Well, I'll be as postive as I can.
If the crack in the manifold isn't too bad and it isn't rusted through one can find a shop to braze it up and hope for the best. Or find a replacement- they are't that costly. My 3L ran ( not great,) with a crack in the exhaust side and water in the cylinders found during a compression test.(how's your's BTW?) My manifold gasket was bad too -
Tons of water in the oil after 6 hr run...
Plug your block, pressurize it and see if you got a leak. I have been advised to do the same and have not found a leak in the block from the water jacket to the lubrication side.
No harm done by lookin', hey? What's to lose at this point? Good luck:)
water is in the oil, can someone give me a positive direction,
Ayuh,... You Need a New Motor,.... Start Shopping....
New, Rebuilt or Used,... Your's is Junk....
This wouldn't have happened if it had been Properly Winterized.....:rolleyes:
Loosingbattle
removed manifold, 5 minutes ago , CRACKED BLOCK, you can shake the boat and water runs out, anyone know a good place to get a short block , any suggestions, all my other parts are good, the engine ran real good, should be a fix I think I can handle , thanks all you guys for all the positive replies, any suggestions on a short block assembly, thanks again.
its cracked 1/2 inch below the head and its about 2 inches log.
