Blackops
Thread starter- Joined
- Aug 1, 2010
- 2
Hello everybody, new to the forum and new to the boat world. I picked up a nice 1985 Stingray with the Mercruiser 3.7 engine. I have a coolant leak coming from the outdrive when the motor is not running. When the motor is running there is no leak. When I pour coolant into the riser tank is goes down rather quickly and I can see the green coolant leaking out of the outdrive where you would put the ears when running the boat out of the water.
I searched the forum for the past few days but could not find a post similar to this. I am assuming that I have a bad heat exchanger and it is allowing the coolant to leak out through the water cooled voltage regulator? When I pulled the seawater intake hose off of the rear side of the voltage regulator green coolant came pouring out fast. I would imagine that in a closed coolant system like mine the green coolant should not be coming from this area.
Thank you for your help with this and I look forward to your replies
-Blackops
-Blackops
