Moose truck
- Joined
- Sep 30, 2012
- 41
Hello, new poster here, but I've been reading this forum for month's. the issue I'm having is on my 3.0 GM (SN 0C856989 ), the DST distributor trigger coil is open. I have a new coil on it's way. I'm not sure how it's changed.
The Mercuriser Electrical Manual makes no mention how this part is changed. The "Star Wheel" that has the teeth that breaks the magnetic field looks like it's fixed to the distributor shaft. See # 7 on the Picture
it looks like I need to pull the distributor, remove the drive gear, & pop out the shaft. Next, swap the coil out and reassemble. This seems like a long way to do this. Am I missing something? Any Help would be appreciated, Thanks
Regards, Moose
HTML:
http://www.perfprotech.com/store/assembly/EST-IGNITION-COMPONENTS,1604-100.aspx
Regards, Moose
