demarko210
Thread starter- Joined
- Jan 2, 2015
- 655
This is a pull start motor with spark and new points adjusted to .02 is very hard to get running. My question is, when I did a compression check it came out 60 psi both cylinders. Is this acceptable for a pull start reading? Also it is very hard to pull. I replace the rewind spring. The motor has been setting I poured some quicksilver synthetic oil in the cylinder and let set for a week and its still hard to turn over. It starts only after i flood the carb with the choke or squeeze the bulb hard enough to flood the carb. It runs then cuts off after 10 seconds. It turns very easy without the plugs, hard with the plugs in. I am comparing to other videos of people pull starting this motor. Can anyone help with this?
