mercury 110 9.8 running on one cylinder
jamesfish
I have a merc 110 9.8 hp (1976) it is only running on one cylinder, i put the coil from the cylinder that not firing on the other cylinder and worked fine,
so i think the coils are okay. I am thinging it is the ignition switch or the trigger, is there any way I can test to see witch one is faulty.
thankyou
Laddies
Banned
Re: mercury 110 9.8 running on one cylinder
It's probably not the trigger as it's a single winding for both cyls. there a good chance it the switch box but heres the test for the system
britabroad
I'm having the same problem with my 9.8. Do you get a spark on the bad cylinder if you pull the plug out and test with a gap tester?
jamesfish
no I don`t get any spark on the bad cylinder ,only time I get spark on that
cylinder is if i switch the two wires from the ignition switch to the coil.I am pretty sure my proplem is the ignition switch.
thanks for the help.
