Mellonhead
Thread starter- Joined
- Oct 12, 2010
- 9
I have a Mercury 110 1976 SN 4391380 9.8HP. I put a new seira water pump kit in. I had the power head pulled to fix some other problems. I put new gaskets in between the powerhead, and drive shaft housing.
When I put is all back together, it doesn't pump water out the tell tail right away, and only trickles out at slow idle. When it isn't pumping water when first started, exhaust comes out the tell tale. It does pump water pretty in gear at higher rpms. The motor starts and runs good.
Does this sound normal, or could I have a water cover or head gasket problem?
I put all new gromets and nylon washers on the water lines?
Thank
MellonH
Thank
MellonH
