MERCURY 115 HP 4 STROKE WATER PRESSURE
clutchrod
2016 MERC 115HP 4 STROKE serial # 2B228284. Is this motor suppose to show water pressure on vessel view and if so what will it be. My vessel view shows 0 psi on water pressure but water is coming out of tell tell and the its not running hot via vessel view. Thanks in advance
muc
"Retired" Association of Marine Technicians...
Water pressure At 650 RPM (idle) 0.7–4.4 psi
At 5800 RPM (WOT) 11.6–43.5 psi
Do you have the 8M0089111 Pressure Sensor Kit? It was an accessory for your engine. It's located on the top of the engine just aft of the flywheel. You need to remove the flywheel cover to see it.
Troubleshooting is covered in the service manual p/n 8M0082471
