BTW, i recently posted another question about corrosion. They didn't seem to be on the same issue, but it is the same motor, so if threads need to be combined, please let me know!
I have been cleaning up my '88 Merc 115hp. It's the inline 6 model.
I have a couple of questions regarding setting the carb float.
1. When setting the float lever, the manual says to "turn upside down. Measure the distance from the face of the shoulder to the secondary level." The face of the carb has two levels. there is an outside lip, and a slightly higher inside lip. If i measure from the outside lip, it is almost perfect, at 13/32". If I measure from the inside lip, it is closer to 12/32". All 3 carbs measure the same, and also measure correctly for the second measurement(upside down with 1/4" between end of 2 levers).
Anyone know which measurement i should take it from?
2. Turning the carb tops in their working position, the needles mostly move free. The top carb needle will occasionally stick momentarily. Would that be a standard procedure to replace for you guys?
