mercury 1150 grayish plug
fishdog4449
hi yall. ran the 1150 for the first time since water pump change. ran fine, idled nicely. pulled the plugs to be sure all ok there.1,2,4,5,6 were all fine. number 3 had a grayish substance on the outer electrode. that felt like oil, but was gray in color. please tell me this is something other than water getting into the cylinder. if so, how could it be getting into just one cylinder?
emckelvy
Re: mercury 1150 grayish plug
Sounds like either the inner exhaust port water jacket cover or the exhaust baffle is leaking and spraying water into #3 cylinder.
fishdog4449
Is that something that needs to be fixed asap or will the motor run for a season or so like that? Also, is that something that requires disassembly of the powerhead?
Benny1963
yes you dont want water damage run a comp check to see if all your cyls are good
fishdog4449
here are compression results
1=121psi
2=135psi
3=130psi
4=135psi
5=135psi
6=135psi
well i was initially worried about the number 3 because of the odd looking plug...but seems number 1 may have some issues!
can one of you inline experts give me some feedback on these numbers?
