mycapricess
- Joined
- Oct 8, 2010
- 11
So i picked up a 1967 Glastron with a 1972 Mercury 1150 on the back. Boat has not seen the water since 1998 and has been sitting in a barn since. I cleaned the carbs rebuilt the fuel pumps put in a new impeller,repaired all the old wiring under the cowl and put on a NOS Merc distributor cap. Now the issues start. The boat will start and run perfectly when on the hose or in a barrel. But the second i put it in the water I cannot get it into gear just stalls when you try. It looks like someone has mess with timing on the boat before. I have found videos on setting the timing but no service when i am at the camp.
I would love to find a service manual that cover the motor and has the procedure in it. Also i am working on a merc 850 with the same electronics and would hope that would info on testing the stator for correct voltage output. Any help would be appreciated. The serial number on the boat is 2932877
