heroforlife911
Thread starter- Joined
- Mar 14, 2011
- 45
What a total PITA! I have been restoring my future father-in-laws Champion Bass Boat for the past year and finally broke the ice on the motor.:facepalm:
The motor is a big piece of ... Mercury 1150
Broke open the cover and started poking around. The wires are shot and fall apart at the touch. Decided to see if she would start anyways. First try was a no go caused by a dirty bendix drive on the starter. Cleaned it off and on the second try I got flywheel movement. By movement, I mean slightly turning without a start. The starter smelt like burnt toast; its original and prob needs replacing anyways.
I attempted to hand turn the flywheel and it was a little tight. Figured its cause it hasn't been cooking in about 3 years. My original though was to rebuild with the basics: carbs, fuel pump, water pump, starter, plugs, gear oil. HERE'S THE CATCH!!
I looked up the S/N online which says the motor is a 1977 HOWEVER; the power plant is defiantly not a 1977. No distributor on it and my guess is that it?s from around '79 based on my research. Not sure the best route for determining what serial number group to order new parts.
ANY HELP IS GREATLY APPRECIATED!!!!!
This pig is broke down to the lower end, power plant and exhaust extension sections.
Everything I listed as an intentional replacement have been removed ...
Thanks for the time!
Justin
Justin
