Captain Nino
Thread starter- Joined
- Jul 9, 2009
- 80
My merc is only getting 4000 rpms at full throttle- in gear. I removed the engine to rebuild the transom and I disconnected the controll cables. When I put the engine back on I just guessed at the control cable adjustment. Is this the problem? How do I correctly fix this?
When I rev the engine with the Idle arm there is a slight lag. (A well tuned car revs RIGHT as you touch the gas. My boat does not do this- at least with the idle arm.) Is this normal? Is it a problem?
When I throw my boat in gear and open up the throttle- once again- there is a lag. Worse yet; the boat begins to speed up slowly (I hit top rpms about 4-6 seconds after I gun it) Then suddenly Bam! the engine kicks in with its power. After three seconds or so of somewhat lagish exceleration Bam! I'm goin! Actualy though, it plains better before the engine kicks in. then it comes off it's plain a little, but it's still powerful enough to keep it cruisin. I don't understand what is going on. Can this be fixed?
The engine is a 1975 merc 1150 long shaft, electric start . The boat is a 1975 16 foot tri hull Imperial. The engine is very reliable. I only bought it in June but it's never let me down yet....It's just....well....a little odd. Thanx for your help.
