mercury 1150 trim pump filler guidance
cuenta619
hi guys can explain me the process to fill the trim tilt pump
the engine needs stay up position or down
and if I'm right with filling hole
Chris1956
Honorary Supreme Mariner
The fill hole is a round head stainless steel screw. You have it right in the diaghram. Tilt the motor fully up and then fill. Originally the PTT held 5W-30 motor oil. Some subsequently used Dextron Auto trans fluid. See what you have in there and refill with the same.
cuenta619
I need to remove the 2 screws to fill? or only the fill s reww
Chris1956
Only remove the fill screw. Use a small funnel to introduce the PTT fluid. When she is full replace the fill screw.
Chris1956
OK, the PTT pump is self bleeding. Run her down and up a few times and refill. After she stays full, with the motor 1/2 way up, pull on the gearcase. If she moves more than 1/4", you need to bleed the PTT cylinders.
