Mercury 115hp carb/power issues
darrelstuart
Very frustrated in MN.
6 July 2009 I took my boat in because it was starting hard. Once it was started it ran fine. I was told a sync the carbs was what I needed. The beginning of my nightmare. It has never run right sense.From 6 Jul to 1 Oct they continued to work on the motor replacing part after part but never solving the problem. What happened was it now started ok but you put it in gear and give it juice it would wind uo slowley to top end and then bog down. If you thru the hammer, for a hole shot it bogged and died. They replaced ALL the electronics, switch boxes, harness,trigger, plugs etc. no change. The cards were rebuilt twice by them nothing fixed the problem. I had an oil/fuel blender on the boat, and they said that was the problem. It was removed and replaced with an automotive electric fuel pump! Still no power out of the hole. Frustrated because I lost the whole season and they wouldbn't give me my money back I stored it for the winter.
I took it to a new mechanic this spring. He said I didn't need all the stuff they did, it was in the carbs. The previous carb work was shotty. They put kits in, synced the carbs. Compression and leakdown were good, timimg was off, they reset it. Also replaced the water pump as it was weak and removed the electic pump.
It ran fine until we tried water skiing. Trying the hole shot with a skier and it bogged and died. It starts up fine but you can't get a hole shot to lift a skier out. You can feather it some and adventually it would pick up speed until you could be running full. Took it back they adjusted carbs and I tried it this weekend and it starts fine, idle fines, but no hole shot, it dies. You can't even feather it up to full power now. Any power more then idle or engaged it it dies.
I am very frustrated, I don't want another season to go by. This ran absolutely great June 2009 just started hard. Now Juky 2010 I have nothing.
Anybody got an idea???????????????
Darrel
Superjetjim
Re: Mercury 115hp carb/power issues
Darrell,
Have you tried a different tank? - Sometimes the pickup inside the tank can get blocked up by debris etc or the pickup pipe can kink as you hit it out of the hole restricting fuel flow if the pipe is a bit old/tired. Might be worth trying/borrowing an external 5 x gallon tank?
Jim
Bob_VT
Welcome to iboats.
Merc carbs are very sensitive and if your carbs had gas in them when they were sored last year you probably have dirt in the carbs.
When you try to accelerate have someone squeeze the primer bulb...... you may have a weak fuel pump....in need of a rebuild kit.
Get a manual for the motor..... you will save $$ in the long run
nitro 39
could be the top or btm mane barring im having the same trouble we skied last week it died an now wont get on plane booging pulled mine down top barring seems to be fine but side to side play in crank will thruogh one out of time
herb boughn
Always check your mechanic first. Mercury will give them a certificate to work their products upon completion of basic lawn mower engine course. I know a guy who is now in charge of a Bass Pro Mercury service dept who put a new water pump on my engine when the problem was an ignition coil two years ago. Felony Stupid :p
darrelstuart
Thanks for the info but, I tried your idea today and it didn't work. Still boggs and kills if you hit it.
Darrell,
Jim
arsenalpsu
Is this an i-6?? If so, you are running lean at WOT, that's why it dies during a hole shot. Seems to me your old mechanic messed up the timing, which the new guy fixed. (and screwed you out of $$$ for parts) What you need to do it move each carb's idle needel out (left) 1/8 turn, then try a hole shot. If it dies again, move each out again 1/8 turn. Keep doing this until you get no hesitation.
What you will notice is that this may make your idle a bit rough, but your hole shot will be good, this is normal and expected. Try it and report back!
PS- did the other mechanic give you your old parts back, if so PM me I may be interested in the switch box or coils....
As for pulling a water skiier, your prop may have too much pitch for that use. If you have too much pitch on a prop, the motor will never get above fast idle.
