I have a 2001 Mercury Salt Water Series 115HP:
My problem is the last two times I have arrived home from using it, when I have connected the bunny ears and hose to the motor to flush it, water has not run all the way through the motor and exited at the tell tale.
The first occurrence was yesterday. The motor had run fine all day in the water and prior to going I had run it at home (at which point water flowed through the tell tale). I got a piece of wire and pushed it up and through to clear/feel for any blockages, there were none.
Today when the boat was put in the water, water flowed through, however, again when coming home it did not while being flushed. Tried holding the bunny ears tightly onto the outboard. Water hose is turned on maximum (which was adequate for my previous boat and has always worked on this outboard in the past).
Any ideas? Could it be a sign of a worn water pump or something like that?
