mercury 120 4cyl removal help
skinny1965
ok due to bad transom the motor is being removed
i see at the rear two large bolts to the inner gimbal plate do I just remove them and take the bell housing out with the motor attached
is there a link some place to this kind of info or a vid I have surfed you tube with out luck
dingdongs
Re: mercury 120 4cyl removal help
select forward and remove drive first then remove bolts as described and undo mounting bracket from floor and remove lump
ziggy
+ remove everything attached to the engine prior to removing. ie fuel lines, many electrical connections, and cables.
the oem service manual can be seen here. it'll have the oem step by step removal process in it.
Fishermark
The only thing I would add - regarding the "many electrical connections" - you shouldn't have to disconnect many electrical connections. Most of the things on the engine will stay connected. Simply pull the main electrical harness and the main battery connections. Then a couple ground wires. Look around and, as the others have said, disconnect whatever looks necessary.
ziggy
FM is right, i made it sound harder than it is. ;)
