racingdave
Thread starter- Joined
- Aug 2, 2020
- 26
Replaced STATOR,TRIGGER,BOTH SWITCH BOXES AND #2 COIL and i still have week spark.Took it out because it sounds good on the muffs but is very low on power in the water,i can tell it is firing on all six by used a timing light to detect ignition spark at each wire.Problem started when i was pulling wires off one at a time as it was running to do a cylinder balance as the motor has been running strong and i should not have done that but i felt a slight miss from time to time at low rpm and was trying to make it perfect.Now it cant get out of its own way and spark wont jump a ST125 SPARK TESER.This cdi system puts out 40kv and should jump the gap of the tester.I did not replace everything at once stator and trigger first then i played the switch box game with a couple i had in the shop before putting new ones on, after the new ones it had spark on 5 cylinders and found #2 coil not working and repaced it and now at least fires on all six.I am thinking i smoked the original stator by pulling wires off ungrounded and i am thinking defective new part or something fried the new part not sure thinking of replacing everthing at once again.Any advise would be helpful i iam going to check all my grounds disconnect the black and yellow,disconnect the rectifire yellow wires to see if hot spark comes back and then guess its the DVA TESTING procedure,i have a DVA adaptor for my meter but never done this before and i manual iam an auto tech for 25 years.ANY ADVISE GUYS?
