mercury 150 blackmax compression
EBENZER
guys i just got a 87 merc 150 blackmax . it has been sitting for 2 years.First thing i did was check compression. the numbers were as follows: left bank 118-118-117 right bank 108-110-108..is it ok for bank to have a difference like these..thanks for help
rabeck5792
Re: mercury 150 blackmax compression
yes,it is normal for 1 bank to have about 10 psi difference,due to rotation & piston rock-over.
EBENZER
so are these number ok for a healthy engine..
rabeck5792
they seem to be,because not all compression gauges read the same.you should really use a leak down tester.
CharlieB
Cold engine, hasn't been run in a couple of years?
With these numbers it should be safe to go ahead, clean the carbs, invest in a new impeller and gear oil, fire it up on the hose and run it 10 minutes at a moderate idle to fully warm up then retest for a much more reliable reading.
It may be just fine for a long time yet.
