Newbie@boats
- Joined
- Apr 6, 2010
- 558
Motor runs like dream at anything past idle......
I replaced spark plugs, removed the carbs and cleaned them also adjusted to floats, and replace all the fuel lines and fuel filters.
Issue is boat will start right up, idle, and then after a few minutes die out.
I played with the idle adjustment screw and either the motor idles way to high or way to low and dies out.
Compression is a solid 127 across all cylinders.
I fell like I got it dialed in, I let it run for about 10 minutes after adjusting the idle and it didn't stall, but I feel like maybe I'm missing something?
If I manaually rev the motor up it will die out but if I use the throttle control at the helm it won't it revs up beautifully, not sure if there's a timing advance or something when I use the control at the helm that makes a difference.
The worst part was idling at the boat ramp trying to get back onto the trailer when there's 15 boats around and 2 feet of water I don't have a lot of wiggle room and when the motor died out it really sucked.
Any info would be great.
BTW, before I adjusted the floats gas would come out of the bodies of the carbs now it does not.
Same idle issue as before, not sure if I am ever supposed to play with that screw or not.
