Matt musky
Thread starter- Joined
- Apr 4, 2017
- 10
#8
April 13th, 2017, 06:12 PM
Hi
After winter storage I can't start my 2006 mercury opti 150. I checked the key switch and kill switch. I have power on the purple wire at the motor . I've tried switching the relays out from the trim still nothing.
I have no power to the coil of the master power relay . If I jump the relay I can get power to the fuses and the fuel pump. I have one side of the coil with 12v to ground ( I put one lead of tester on battery ground and the other in the coil side of the relay harness)but I have nothing if I stick both test leads into the coil with key on. So something is preventing the coil from getting a negitive to close the relay and start the motor any thoughts ? Could it be a sensor in the motor like oil switch or something else ?
Hi
