mercury 1500 tilt trim question
starrtwo
Does anyone know the wiring for these? Its a 1973 model. Is green down and blue up? If you put red and green to battery, will it go down??
Laddies
Banned
Re: mercury 1500 tilt trim question
Blue is up, green is down, and the power wire is red
starrtwo
so if I am trying to make it work, do I put red to positive on battery and green or blue on negative?
Laddies
Banned
NO, you need a ground wire to the pump motor, a hot wire to the solinoid, a fused red going from thr solinoid to the switch, from the up switch a blue should work the solinoid and the down wire is green and goes to the green from the pump motor
