I have a 20hp Mercury. I have set the timing on the motor. Cleaned the carb. I have 140psi both cyl.
I have great spark. Will jump 3/4 or 1 inch gap.
I did an ohms readings on coils compared to my 25 . They are in spec . I spray starting fluid in carb buttterfly open , then turn key it fires like a backfire not a run. Then if if I turn key again I get fumes out the carb. So I took the plate off to look at the reeds . They look good but 2 of them .
So I have spark, compression, fuel but will not run.
Open to suggestions.
If I put starting fluid in cyl won’t start either.
I can only think that stator is not putting out enough spark?
Can someone tell me what the readings should be on stator .
Thanks for the help
Dale
Thanks for the help
Dale
