Andrew Japatul
Thread starter- Joined
- Aug 19, 2026
- 1
I believe Ive checked or replaced everything and sill no luck. It will run on the middle cylinder only with throttle advanced. Started with fuel pump. next to carb clean and rebuild. Replaced coils. Checked compression and got 110/110/105. Replaced reed valves. Checked timing. Ensured the needle in the carb was seating properly. Ensured there was sufficient spark. we are stumped
