I have a 2005 2+2 115hp.
It runs great when running on all 4cyls, perfect actually.
At times, idling is the problem. Not all times, but about half the time it idles very rough, and smokes a lot. Other times it idles perfectly for long idles into large marinas.
I'm wondering that perhaps the fuel or spark isn't being stopped below the ~1900 RPM and thus causing the rough idle.
So the question, what exactly causes the motor to switch from 4 to 2 cyls?
Things I've tired:
Rebuild carbs, twice, once this year, once last year, no change, inside of carbs clean.
New spark plugs, adjusted the "sync" of carbs per manual, etc.
Substituted a new coil through each of the 4 coil positions, no channge.
Also tried different gas, no ethanol, hitest, etc.
What actually shuts off the 2 cyls at low RPM, is it centrifugal, vacuum, magic?
Thanks in advance,
CPS22
Things I've tired:
Thanks in advance,
CPS22
