mercury 200 thunderbolt
Eshaw150
Looking to buy an older 14ft fiberglass boat with a mercury 200 thunderbolt. Is there anything that i need to look out for. Also are these good motors to have.
Eshaw150
Re: mercury 200 thunderbolt
anny body know
blue line
james33
Lets just say i sunk one of these motors for 24 hours. pulled it up dried it out and it started and ran like a dream. These things are beasts. Solid motor
7920hpMercury
Assume this is for the 20hp, I did not see the year I think.
Great motors, agree with above. One of the most popular Mercury made, right up there with the 4 cyl 50hp.
If from the seventies, couple of thoughts to look for:
*check the lower unit oil. the lower unit was the weak spot of the motor relatively speaking. You can bend the prop shaft if you run over enough snags, logs ect. This is likely true with any motor though.
*up until 74, the drive shaft was all carbon steel and so rusts. swap out to the ss shaft if possible. Or Grubbs makes a ss sleeve for the carbon steel drive shaft if you want to go that way.
*wiring tends to rot if original, the wires were a fine aluminum and corode over time.
Good luck!
Eshaw150
not sure of the year but ill check into that stuff when i get it home im picking it up with a 14ft boat friday
