Mercury 2004 Bigfoot 4-stroke 9.9 oil pump leaking, need seal...
rvbrlb
Does anyone know where to find the odd-shaped o-ring-type seal (item 'F') for pump 834967T 2? The pump is now obsolete from Mercury. I can find replacement pumps online, but really only need the seals...
Teamster
Not long ago I needed some gaskets for a Merc 9.9 kicker,...
That Merc no longer makes or sells,..
I tried looking here on I-Boats first, They didn't have them and didn't think they would, But I tried,..
I found one of the gaskets at MarineEngine dot "you know",..
And the other gasket at GreenBayProp dot "you know",...
Might be worth looking there for new old stock stuff,...
rvbrlb
Thanks for the info, guys. I figured I was headed down a dead-end road, but wasn't even sure how to find a parts breakdown of a component part like the oil pump. Was hoping that maybe the seal was still an active/available part, since it could possibly be used in later versions... wishful thinking I guess. I'll keep checking, thanks again.
Teamster
MarineEngine dot you know had schematics, Might be worth digging around there,..
Or, Just order the new pump and be done with it,...
