mercury 225 efi overheated ?
bandit01
I recently purchased a Mercury 225 efi.I would like to know if there is a way to visualy tell if the engine has been hot before.There was some white looking stuff on the sides of the lower unit right below the bottom cowl that came off with rubbing compound.The engine runs fine and compression is good.
rodbolt
Re: mercury 225 efi overheated ?
hello<br /> look for any melted wires along the block or melted plug wire boots. other than that not much way to tell.
lmoreau
Sounds like that may have been some corrosion...white powdery stuff?
KCLOST
hunter, that white stuff is not a result of overheating, it's just deposits from water...
BW23
Originally posted by hunter100:<br /> I recently purchased a Mercury 225 efi.I would like to know if there is a way to visualy tell if the engine has been hot before.There was some white looking stuff on the sides of the lower unit right below the bottom cowl that came off with rubbing compound.The engine runs fine and compression is good.
My 97 225 EFI shows the same minor white stuff. (saltwater use)<br /><br />An overheated motor will also show signs of paint peeling(different than corrosion) on the heads and block.
