JackBronson
Thread starter- Joined
- Jun 4, 2012
- 170
Hello,
I have a Mercruiser MCM 230, 230HP 5 liter, engine serial number B530375, drive unit serial number 0B539283, Alpha 1 on a 19' Starcraft. The issue I am having is that after about 30 minutes of boating the engine will lose power and stall. I have been able to get the motor started and was able to drive it a short distance at a very low speed, keeping the RPMs at about 1000. If I try to power up beyond that, when it gets to around 1500 is bogs out and dies.
The boat had two fuel filters. The filter in the carb (it is a Rochester Quadrajet) I removed as it was filthy. There is an inline glass fuel filter that I disassembled (it is a Spectre brand from AutoZone), cleaned and replaced the cartridge.
It seems an awful lot like a vapor lock situation, as it only happens after the engine is warm. However, the previous owner put a Sunpro temp gauge on the boat and its never gone above 160 (and the first time this happened was in the ocean and it was at about 140) so it's not like the engine is getting overly hot. I am wondering if it is the engine compartment that is getting too warm, and contributing, although that would seem unlikely. It is warm in there when I open the compartment, but it doesn't seem like an oven.
After the motor cools down for a half hour or more it runs fine again. Can pull the kids on the tube for a while and then it happens.
There ARE times I check the glass fuel filter and it seems like it is empty, but I don't know if it is always supposed to have fuel in it. I just can't recall if the times I've seen it empty are the times I've been having the problem. The boat has a full tank of fresh fuel, and I also threw two cans of Sea Foam in it, which may explain all the crap in the fuel filters I replaced.
Any suggestions for why to try next would be greatly appreciated. Thank you.
