Re: Mercury 25 Help
While you have the carb off, I would get a re build kit for it. Wonder if water was in the gas when it was put up? You could get a set of Boyson reeds and replace your old rusty ones with them...probably a lot cheaper than factory reeds. While you are at it you should probably replace the water pump or at least the impeller.
