FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
in neutral i can rev engine all the way up.... in gear it wont rev over 2000 rpm, which makes about 7 mph. compression is 90lbs and even across all six cylinders...... any help would be appreciated
spark is good.....across the board. could it be a bad cylinder? I have even pressure of 90 lbs compression, but could i be leaking it down, or maybe bad gasket? I dont really want to open up the head until i`m resonably sure it is a head problem.
could the computer gone into gaurdian or limp mode? i would think that it would be unable to rev in neutral if this were the case, but i`m not sure.... any insights would be appreciated
Does your alarm work? You should get beeps when key is first turned on indicating self test ok. When you ran it out of oil, should have triggered the alarm. The computer may be in limp mode possibly due to faulty float/sensor in your reservoir tank and your alarm would be sounding but you don't know it.
