Earl Keese
Thread starter- Joined
- Sep 7, 2009
- 2
I have 2003 Merc 25 Bigfoot - Motor has history of running poorly since new. Very low hours. Believe it to be fuel system. Motor will run then shut down, usually at high rpm. Once shut down will not start again. Can run for 10-30 minutes. Sounds like it is running out of gas but there is plenty. I have replaced lines, filter and gas tank. Mechanic has cleaned and adjusted carb. I have changed plugs, and had a water seperater filter added. This year mechanic replaced the fuel pump as the diaphram was ruptured. It ran great for 30 minutes and now doing all the things it was before. I know gas is ok as I run it in other boats. Extremely frustrated with this motor. Is there any thoughts as to where to check next?
