Mercury 25hp engine dies
PSHAFT
I have a 2002 Mercury 25hp remote start motor. Engine will not start unless I pull out the manual primer knob located on the outboard. Then the engine will start and will run until I push the primer knob back in. The engine will run for 15-20 seconds then dies. I have cleaned out fuel system, repalced fuel, replaced spark plugs, sprayed carb with carb cleaner. Does anyone have any ideas for me on what the problem may be? I'm baffled!
ddennis
Re: Mercury 25hp engine dies
rebuild the carbs....do you have a service manual?
Plainsman
If it stays running while you squeeze the primer bulb, could be the fuel pump needs a rebuild.
PSHAFT
No, don't have a service manual. Carb was serviced about a year ago, carb kit installed by dealer. Does the carb need to be serviced that often? It hasn't had that many hours on it since serviced.
