Scott06
- Joined
- Apr 20, 2014
- 7,620
if it is not moving around at idle it is locked in base mode. Module only in there. I would try as AD suggests pulling the plug off. Only thing I can think of is if you are getting 12 v to the base mode wire ...I put in base mode per directions in service manual, which has you jumping the two wires on dist, and bypassing shift interrupt. I set to 1* BTDC.
Once I take unhook wires on dist and put shift interrupt back it's still at 1* BTDC (should be 12* BTDC with advance at idle). When I rev it up, it has a hard time and timing is still at 1* even at 2,000RPM or so.
I've tried OEM module, cheaper O'reillys brand and another module and none of them are advancing. But I really can't think of anything else besides the module that would affect advance.
Assume balancer hasn't slipped such that you are not actually at TDC ... grabbing at straws
