Mercury 40 only runs for 5 to 10 sec
MercHelp
I have a 1981 40hp Mercury. It's starts and runs for only a few seconds then
stops. I have checked the fuel pump and gas flows pretty well, I have taken the carb off and taken apart and cleaned but still the same results. Any other suggestion that may fix?
Thanks!
Dunaruna
Re: Mercury 40 only runs for 5 to 10 sec
Exactly how do you get it RE-started? Do you have to pump the primer bulb?
MercHelp
Yes, If I pump the primer bulb it will start,
MercHelp
Fixed the problem!! turns out that the idle adjustment was not opened enough .
Dunaruna
Good news!
I was going to suggest that the primer bulb valve was due for replacement but no need now.
