I purchased a boat last summer with a 40hp 2 cylinder 2 stroke 402 Merc on it. I have never owner a boat and know nothing about outboards. I am decent with a wrench though.
The engine had some overheating problems and sputtering.
This winter I have been trying to fix everything so it's ready for the Spring. I popped the cover and saw a blown gasket between the block and plate that holds the spark plugs. The plate was cracked and repaired with JB Weld apparently too. I removed the old plate and of course some of the bolts broke.
I finally have all bolts removed and new gasket and plate on. However, the bottom cowl restricts me from inserting the bottom bolt and properly tightening it. I cannot see a way to just remove the bottom cowl. Any idea?
I removed the lower unit and found the impeller to be trashed. Ordering a new one. Anything else I should look for in the lower?
Removed the transfer port cover and found the poppet and all related grommets to be melted. Ordering all new components and t-stat.
What other suggestions do you have that I should look for? When running, the telltale had water flowing from it. I am a little apprehensive about taking apart the carb to clean it properly as I have no idea how to adjust it when done. I was thinking of just cleaning it the best I could while together and using some carb cleaner. Any advice on this as well?
Lastly, I'm thinking that this motor is too old and won't support an onboard battery charger, is this correct?
My serial number leads me to believe that this is a 1973 model.
Final question is that when I look up parts, there is always multiple categories that my serial number falls under.. not sure which to choose. Also, there is a "cylinder block and coil mounting bracket" category for Serial group #3 and serial group #5. Noone can tell me what that means.
(My serial number is 3727480)
http://www.boats.net/parts/search/Merc2/Mercury/402/parts.html
Hoping to get this engine fixed up quickly and I also have a 1978 Mercury 500 that appears to be in awesome shape, but I have never seen it run so it's a big mystery for now. Once the 402 is good, I would like to try out the 500 and hope that it's in good condition. Any suggestions on things to look at before I attempt to fire it up?
Sorry for all of the questions and thanks in advance
