Installed a new impeller in 1970-71 Mercury 400 40hp 2 stroke 2 cylinder motor. Had the control box in forwards but the reverse cam was moved when I had the lower unit off, I?m not sure how to re-align ? Put it back together with the reverse cam in the middle when in neutral. Now will only idle along in forwards but reverse will run at full speed and throw the motor out of the water. Is there a way of re-aligning the reverse cam and is this the problem ?
