Mercury 40hp outboard problems
johnbuczek51
Just purchased a 1973 14' Starcraft Holiday which has attached to it a 1973 Mercury 40hp outboard. Immediate problems appear to be (1) motor is frozen and unable to pull. (2) controls are locked cannot move into gear with-out motor running. Any suggestions as to what to look for?
..........thanks john
GA_Boater
Re: Mercury 40hp outboard problems
It's a salt water boat, isn't it? I'd drop the lower unit to see if the motor is stuck or if the lower is rusted solid due to water intrusion. Given the lack of shifting, I'm leaning toward the lower for starters..
johnbuczek51
Thanks for the quick reply however boat & motor have only been in fresh water.
Laddies
Banned
Take it back to the seller and get your money back, it started out trouble and will only get worst.
johnbuczek51
I appreciate your advice, however for $500 I got a 1973 in excellent condition 14' Starcraft, with a fairly new trailer and the motor attached. I think the motor can be salvaged.
.......thanks john
GA_Boater
Since you're keeping it, drop the lower to find out what's locked up.
johnbuczek51
Will do.... seems I saw something of this in an older thread. Thanks
johnbuczek51
OK... so I thought I saw something about the lower unit...........however I have no clue as to how to "drop the lower unit"
Any suggestions..............maybe some pics to help
bgc
Ensign
Best money you can spend on this motor, Mercury Manual (not the Seloc)... Manuals
johnbuczek51
Gerry.... thanks for the link & info. I was able to download and save. I posted this because the controls are "locked up" and someone posted in reply "Since you're keeping it, drop the lower to find out what's locked up."
Again thanks.......john
PS: SN - 3475092
Year - 1973
2 cyl. 40 hp
GA_Boater
PS: SN - 3475092
Year - 1973
2 cyl. 40 hp
That was me. I suggested dropping the lower to determine if the motor is frozen or if the lower is frozen. And I also said given the inability to shift points to the lower. But you have to start somewhere and It's a good a place as any.
I missed your reply or I would have clarified.
johnbuczek51
Thanks. Now I might have be able to determine if there is a problem. I should be able to drop the unit using the picture in the manual that Gerry provided a link to.
Thanks............john
PS: I just noticed you have a Starcraft powered by a "merc" also...........john
GA_Boater
Sure do. A great combination. :D
